Re: Umgang mit Shapeways
stadtbahnzug
Beitrag von stadtbahnzug »
Hi Martin,
But if somebody else wants to, and is capable to develop the chassis, I can give him maximum support (all important inner surfaces of my 3D model) to do that.
Which program do you draw with ?
Regards
Oliver
Viele Grüsse von der Ostsee
Berlin in Maßstab 1:87
http://www.berlin1zu87.de
czhunter
Beitrag von czhunter »
Hello Oliver
I work in Rhinoceros 5.
So I can give either NURBS data in IGS/STEP, or polygonal (not very optimised, but workable with) in STL or 3ds.
Martin
Schienenchaos
Beitrag von Schienenchaos »
czhunter hat geschrieben:Hello Oliver
Martin
Which settings do you use for converting your models to stl-files from Rhino?
Schienenchaos
Von Rhino muss nichts konvertiert werden. Man kann direkt STL speichern.
czhunter
I'm doing the conversion, because I don't believe in uploading Rhino file directly (sometimes the model has to be repaired, and it is easier to repair STL in NetFabb or similar, then .3dm file)
Setting is not so easy, default setting for H0 is in attachment.
For N - TT - H0 - 0 the main difference is Maximum edge length (0,8 - 1 - 1,2 - 2 mm)
If the file is too big, then I increase Maximum angle (up to 8 degrees) and Minimum edge length and Maximum distance edge to surface to 0,05 and 0,05 (0,1 and 0,1 for 0 scale).
If the file is still too big, then it has to be meshed manually (look for the most dense object, exported with separate settings).
The rest (Density, Aspect ratio, Minimum initial grid quads) are not interesting.
Rhino 6 will have brand new and much better algorythm for meshing (new command: Quadmesh):
http://3dakademie.cz/2015/05/rhino6-prikaz-quadmesh/ (in czech, sorry)
czhunter
Mickybaer hat geschrieben:2) Now the big question --> when? :D
Today is your lucky day! :-)
https://www.shapeways.com/product/AJW2H ... d=63990345
Martin
Mickybaer
Beitrag von Mickybaer »
Thanks ,thanks ,thanks!! :P :P :) :D
Mickybaer
heute ist ja Black Friday und dementsprechend ist ein Angebot auf Shapeways zu finden.
Gilt das nur ,wenn man einen Artikel kauft ,aus seinen eigenen Shop (,den ich bicht habe)?
Aktion dürfte kostenlose Versandkosten sein.
Ja, das Angebot gilt nur für selbst hochgeladene Modelle.
cesitram
Beitrag von cesitram »
da die Preise immer höher werden, wer bestellt da noch?
Grüsse Cesi
Das hängt in erster Linie davon ab, ob die Designer ihre Modelle/Entwürfe auch bei anderen Dienstleistern anbieten. Speziell im Vergleich zwischen Shapeways und i.materialise kann ich soviel berichten:
Mit Hilfe des Designers "czhunter" bzw. "Martin" entstand kürzlich die Druckvorlage des T7B5. Er hat dieses bei Shapeways und bei i.materialise eingestellt. Der Preisunterschied ist signifikant. Und auch der Materialunterschied ist deutlich. Ich habe das Modell über i.materialise bezogen. Das Resin ist gut zu bearbeiten, recht stabil und trotzdem nicht zu spröde. Gegenüber dem SFDPlastic von Shapeways ist das Resin weitgehend geruchlos und nicht fettend. Allerdings ist bei der Bearbeitung eine Atemschutzmaske sinnvoll, der Schleifstaub des Resins ist sehr fein und nicht unbedingt gesundheitsfördernd.
Ein weiterer Gegensatz zwischen den Anbietern ist der Erstdruck. Bei Shapeways kann jeder etwas einstellen, wenn es beimn Anbieter durch die Testberechnungen durchgeht. Bei i.materialise muss der Designer vor dem Einstellen in einen Shop einen Probedruck bestellen. Wenn nach dem ersten Druck nochmal Änderungen vorgenommen werden, ist wieder ein Probedruck nötig.
Insoweit hilft es vielleicht die Designer bei Shapeways direkt anzuschreiben und zu fragen ob man einen Weg findet die entsprechenden Drucke bei anderen Druckanbietern einzustellen.
cesitram hat geschrieben: Sa 23. Mai 2020, 14:56 Hallo,
Grüsse Cesi
Leute die feinere und detailreichere Modelle wollen.
i.materialise hat z.B. eine minimale Wandstärke von 1mm Shapeways hingegen von 0,6mm für alleinstehende und 0,3mm für unterstützte. Außerdem muss bei Shapeways die Stützstruktur nicht mechanisch entfernt werden weshalb man kompliziertere Geometrien ausdrucken kann.
Und am wichtigsten für mich, bei Shapeways kann man im Gegensatz zu i.materialise mehrere Teile mit Verbindungen zu einem zusammenfügen und als eines ausdrucken lassen was i.materialise leider nicht zulässt. Dadurch geht der Preis bei i.materialise für ein komplettes Modell sehr schnell nach oben.
Weshalb beim T7B5 so ein extremer Preisunterschied ist würde mich auch interessieren.
Man sagte das geht nicht. Dann kam einer, der wusste das nicht und hat es gemacht.
www.Tramwaybastler.at
Für welches Material der beiden Dienstleister gelten denn die Aussagen? Nicht dass hier die sprichwörtlichen Äpfel mit Birnen verglichen werden. Auch sollten die Nachbehandlungsarbeiten nicht unbeachtet bleiben.
Ich hab die Material von Spreeathener verlinkten Beispiel genommen.
Man kann aber anhand den Design Guides auch SLA mit SLA vergleichen.
Matthias Pietschmann
Rabattaktion bei Shapeways
Beitrag von Matthias Pietschmann »
zum "Cyber Monday and Tuesday" gibt es heute und morgen wieder Rabatte auf die Bestellungen bei Shapeways.
Bei Bestellungen zwischen $50-$199 werden 15 % Rabatt gewährt, bei Bestellungen über $200 sind es sogar 20 %.
